1 - 12 of 12 Posts
OK guys, I think I want a 5" exhaust for the sound. I was going to go with the 4" DP, but have heard that I will lose HP and mileage unless I go with the 3.5. It is hard for me to understand why this would be the case. I would think that more flow is better. I would be interested in personal experience - preferrably backed up with some data. Then an explanation as to why would be nice. I hope to only spend money on the exhaust once to get what I want (good mileage and good towing setup). BTW, I plan on getting a DP Tuner and Jody says I want 3.5" DP and 4" exhaust. I just haven't gotten a real good explanation as to why this is best.
John Wood Nut Swinger
The stock turbo outlet is 2.8", the high flow outlets are 3.2".
Info can be corroborated here:
Diesel
The Fat Mod
BTW, the 5in setup's are for bragging rights only.
Maybe, but mine sure did sound good :D
The OP said he was doing it mostly for sound. It is over kill for sure, but maybe someone will need to get a honda out of the rain :wink[3]:
Discussion Starter · #7 ·
OK, thanks for the input. Let's explore a bit more:
I agree that 5" is overkill, but hey it just might be cool and I could use cool points :hehe:
I will do a DP tuner some day (after gauges). From what I have read, I may end up with Turbo Surge. Then I have a choice of an ATS housing or WW. I already have some pretty good Turbo whine with the Foil delete and Airaid intake. I have also heard that the WW is less efficient than stock - not sure what that means or whether I want to go there. I would then lean toward the ATS. What is its outlet size and does this change whether I should go with 3.5 or 4" DP?
BTW, I am straight piped now.
Mike.
The ATS is on the compressor side of the turbo, it does not affect the down pipe side. That is still up to you.
The WW changes the surge line further up the turbo MAP. In effect it is less efficient in the lower RPM than a stock wheel. However the trade off is surge being eliminated. The wicked wheel can help eliminate surge.
That ATS housing is a ported housing that eliminates the surge completely.
Didn't Maintain and scuffy and sea71 do a before and after dyno with the WW and I think it was only 1.5 hp less with the WW on...FWIW...
later
i just got done puttin a WW, 4in down pipe to 7in stacks on mine sounds awsome. noticed a increase in power and no loss of boost and my turbo surge went away. and it def made my turbo wistle a whole lot more. from personal exp i recommend a WW and a 4in down pipe.
1 - 12 of 12 Posts
