Will the switches you listed work in a 6.0 as well or only for the 6.4?I think this is what your looking for, second post down:
http://www.powerstroke.org/forum/6-...tra-auxiliary-switches-uplifter-switch-2.html
Here's a set of upfitters on ebay for $35 I found too:
FORD SUPER DUTY F250 F350 F450 F750 PICKUP TRUCK UP-FITTER AUXILIARY LED SWITCH | eBay
I believe that the 6.0 and 6.4 use different sets because the computer is completely different in the 6.4, here are the wiring diagrams for both styles:Will the switches you listed work in a 6.0 as well or only for the 6.4?
Correct but just search ebay and there are other on there with wiring too:It looks like that is for the switches only, not including the harness and relays.
