Has anyone installed one and if so which model and did I wire to Aux up fitter switch?
R rgm · Registered Joined Mar 24, 2017 · 5 Posts Discussion Starter · #1 · Apr 25, 2020 Only show this user Has anyone installed one and if so which model and did I wire to Aux up fitter switch?
HeavyAssault · Premium Member Joined Oct 17, 2007 · 12,442 Posts #2 · Apr 25, 2020 Only show this user Amp draw will drive what upfitter switch you use.
R rgm · Registered Joined Mar 24, 2017 · 5 Posts Discussion Starter · #3 · Apr 27, 2020 Only show this user HeavyAssault said: Amp draw will drive what upfitter switch you use. Click to expand... draw is 7.5 AMPS
HeavyAssault · Premium Member Joined Oct 17, 2007 · 12,442 Posts #4 · Apr 27, 2020 Only show this user Well under the limit for the lowest rated switch. I'm not 100% on which one so check your owner's manual for the switch ratings.
