1 - 9 of 9 Posts
I have a 2019 f350 with 3800 miles today it went into regen on the interstate and stopped at 55% and didn’t finish it did start to rain but I didn’t think that would make it stop. I stayed on the interstate for 20 more miles and it didn’t change
So you were driving along the interstate when you saw the regen stop with 55% left???
Yes and I was doing 65 it started raining so I don’t know if that had anything to do with it this is all new to me going to call dealership but we all know how that works
Assuming you have the DPF% on your dash and that is what you are looking at, it does not go down to 0 every time. It doesn't ever stop at a particular number in my experience. Nor does it always start at a particular number (except "full", it always starts there). I have had it start as low as 65% and stop as high as 55%. The truck will start a regen cycle after 500ish miles no matter what. Ive been towing and had it start at 50%.
Ok thanks just been very careful to try and let it do a full regen I added the Gage with four scan
The truck will do what it needs to do :) Just drive it as you normally would. The DFP% is like stop signs- just a suggestion. It is not an absolute. I used to take a longer way home when the regens started. Not any more. I just drive it like I don't know. Never got a "drive to clean" warning yet.
I’ve had a regen stop at 45% while driving at highway speeds before. The next time I got into the truck it was down to 10%. No need to worry.
I do the same...just turned over 5000 miles on the ticker last week and got a service on it.
Don't know if they didn't purge the air from the fuel lines properly from the factory or what but man when I drove it after they changed the oil and fuel filters it was a rocketship!
Throttle response has been the same since last week so I have to believe that's what it was.
1 - 9 of 9 Posts
