That’s not really how it works. They have different turbos but the pressures will still be in the same neighborhood if operating correctly. Changing a turbo doesn’t necessarily mean a different boost pressure and that’s what you are reading on the gauge, it’s a pressure meter, not a flow meter.
Macd... thanks for the explanation, I fully understand how pressure and flow relate to each other. My original question was to try and gain some insight into what other people are seeing who are actually running the same Gen 2 6.7 Powerstroke under similar conditions.
However I think I figured out the issue..... I took out the MAP sensor, cleaned it ( it was plugged with soot ). Took the truck for a drive and watched boost pressure closely ( BullyDog numerical value not "tattle-tale" gauge on dash).
Initially it still built upwards of 37psi when WOT from a roll, ( truck warmed up and on flat straight road ) .
After a short drive however it now tops out a 32psi....which is what I was expecting. Driving to work this morning it also topped out at 32psi.
Seems like the GT37 VGT turbo and PCM must have some "learning" that is happening after cleaning a MAP.
Compared with a co-workers 2013 6.7 with the previous GT32 model turbo on the way to work ( also deleted and running a H&S tuner ) , his maximum boost under same conditions was 23psi.
He stated that originally his tune made 31psi, however H&S contacted him and suggested he update his tunes and now he see's 23psi as maximum. ( H&S explained to him that anything higher on the GT32 turbo and things begin to fail )
