1 - 5 of 5 Posts
· Registered
Hello all,
I have a 2015 F350 Platinum SRW
The back up camera is inop with the camera unavailable msg.
I am about out of ideas on this problem, so far I have done the following.
1. Replaced the camera to body harness that runs up into the tail gate. No fix
2. Replaced rear camera also no fix
3. Disconnected and reconnected harness underneath the dash behind the parking brake. No fix.
4. Replaced fuses 49 under hood and 29 passenger kick panel. You guessed it... No fix.
Does anyone have any suggestions on the next thing to try?
The only thing I can think of is start ringing out wires, so that being said does someone have the wire schematic for the back up camera system for this 2015 that they would be willing to share?
Any help would be much appreciated, thanks in advance.
· Registered
There is a special grease I use for connections like this. i get it at the dealer. IUt's just called Motorcraft electrical grease. I suppose you can use Di-electric grease just the same but I don't know if they are the same.
1 - 5 of 5 Posts
