Can anyone tell on a 2014 powerstroke what the three plug ins on the ecm do? I deleted my pickup the other day and the instructions said to remove the ecm for removal of the egr cooler, which i did, but think that is not necessary. Anyway i'm throwing a 132a code and the only symptom i have is a sluggish throttle response but runs fine once turbo boost comes up. No codes before the delete and ran fine, so i suspect a bad electrical connection. It has had the dpf delete done before i got the pickup and has an sctx4 tuner. The 3 ecm connectors was all that was undone.TIA
