Was wondering I have a 2003 f250 King Ranch and I am looking at a set of 2013 8x170x20 8 lug factory King Ranch rims should be a direct fit I would think?? Thanks Mike
they will have a different backspacing since they were changed throughout the years, should be sucked in at least 1.5" but get yourself a quality set of 2" spacers and they should be fine.
Lug pattern fits no problem but like Big stated the spacing is a little different. I put 2010 20" OEM wheels with stock size tires on my 2000 -250. The tires rub on the front leafs if I turn all the way one direction or the other. Just makes tight 3 point turns now be 5 point turns. I may look into some spacers but will only do steel if that is the route of which I go. I was reading another thread where there seemed to be some serious problems with some of the aluminum spacers. I believe the general consensus was that this was the best way to go:
Welcome - Arrowcraft :: Helping You Handle the Road for over 30 years!
