2012 Ford f350 6.7 lariat w/ 9" lift icon coilover/ouo set quad shocks 37's 77k miles
Located in Appleton, WI. PM or call/text 414- eight four zero- 5364 if interested!
For sale is my 2012 Ford F-350 Superduty Lariat. I bought this truck brand new from the dealer and am the only owner. It currently has 77,450 miles on the odometer (may go up slightly since i do still drive it.)
Specs are...
Supercab w/ 8' long bed
Heated/cooled seats, navigation, upfitter switches, 4x4, off road package snow camper package etc. I have the original window sticker.
Modifications-
Engine/fuel-
H&S mini maxx w/ H&S dash mount kit
Fluidampr crank pulley
No limit Fab EGR pass thru plate
No limit Diesel EGR delete kit
No limit Fab crank case kit
H&S low pressure fuel pump w/ underhood filter housing kit
XS Power Dual batteries
Mishimoto aluminum Radiator
AFE cold air intake system
AFE transmission pan
Turbosmart bov control module
Tial bov
Beans diesel fuel sump kit.
5" MBRP downpipe back exhaust with DPF delete. Rear section of the exhaust is not shown but will be included with an RBP muffler. Everything connects with 5" v-bands!
Suspension/drivetrain/brakes/etc.
Swayaway hydro assist w/ steering damper
PSC motorsports modified steering gear box
OUO Front truss w/ welded cover
OUO Rear truss w/ welded cover
SPE differential lock
Icon track bar
OUO track bar joint
OUO drag link
OUO ladder bars with bolted 10" OUO blocks
Upgraded U-bolts
OUO quad shock upper bracket
OUO 3 link setup
OUO driveshaft drop kit
Pro Comp Pitman drop
Pro Comp track bar drop bracket
Dynatrac free spin wheel bearing upgrade kit
Dynatrac rebuildable ball joints
Wilwood big brake setup from TCE front/rear w/ steel braided lines
Icon front coilover setup with dual CDC valve shocks (adjustable)
Icon quad rear shocks with CDC (adjustable)
Interior/Exterior
RBP Grille with surround clear wrapped
Smoked oem clearance lights/tail lights/side markers
OEM headlight retrofit- Amber background with oracle halos & morimoto's
BMF 22" novakane rims w/ 37" nitto trail grappler tires
Hypertech speedometer calibrator
OEM Ford fender flares paint to match
RBP gas tank lid w/ key
Custom F-950 from billet badges
Custom punisher billet rear emblem from billet badges
Custom painted 6.7 door badges
Roll n lock toneau cover
Interior panels wrapped with urban night camo (can be removed easily if needed)
Nav screen has clear wrap from brand new
BD diesel high idle kit (adjust as needed)
Whelen public announcement kit with electronic horn
Formula one Pinnacle 50% Window tint
Lockpick installed in Navigation
LED lighting
Helix blue front+ rear speakers
Door lock and tailgate guards installed to prevent break in's. Interior unlock delete
Roll n lock cargo cover
All doors are dynamatted with dynamat xtreme inner and outer shells
There are much more modifications done that I just can't think of off the top of my head. I put a lot of money in this truck. Interior was never smoked in and is like new. Only selling because I plan to build a 2018 F350. I want $45,000 for the truck. Serious inquires only. Located in Appleton, WI. PM or call/text 414- eight four zero- 5364 if interested!
More pictures shortly.
