1 - 5 of 5 Posts
I have a 2012 F350 with the 6.7. It is bone stock with 79,000 miles on it. I'm looking for some info on lifting it. I'm not sure how high I can go before I start messing with the axles. I think I want more than a leveling kit but also don't want to go crazy. I was thinking about maybe a 3". Any info would be greatly appreciated. Thanks in advance.
Axle wrap is there even with stock height trucks. It's just not as detrimental as when you are lifted. For axle wrap the use of traction bars like OneUpOffroad will eliminate any concerns with axle wrap. Even better is OUO has a lift block that incorporates their traction bar mounts. Just depends on how you want to use them.
Ok thanks. I've been looking at the Readylift 3.5" lift for my truck. Then adding 35's to it
1 - 5 of 5 Posts
