1 - 2 of 2 Posts
I have changed my fuel filters many times. Yesterday I was changing them (Motorcraft) and the bottom filter kept pouring fuel from the threaded area even after i tightened all the way to the stop. I took it on and off a few times with the same result. Finally I put the old filter and o ring back on and it was fine.
The new filter and o ring was exactly the same with the same part number.
Also I found a tiny spring in the pan after? Could that be the issue??
Try the new filter with the old o ring to see if that helps. Could be the o ring not sealing properly.
1 - 2 of 2 Posts
