1 - 13 of 13 Posts
Hello,
Back in November 2010 i purchased a brand new 2011 Ford F 250 Powerstroke. About 6 months after I had it I noticed that my rear automatic sliding window was leaking,leaving water on the inside of my back window and some of my seat. Now it doesn't leak when it rains, just when i run it through an auto wash or when i hand wash with a regular garden hose. When i took it to the dealership for this problem they stated that they weren't sure how to fix the problem and they would have to contact the Ford tech-line for further instructions.Keep in mind the sticker price on this truck was(are you sitting down) $60,155. So the tech line then contacted my dealership a few weeks later and stated that they didn't have a fix for the problem at this time. So my service manager stated that i should contact the Ford customer relations department and tell them the problem and that they would handle it from here. Kind of weird that i would have to call,but i did and stated my problem with the Ford CRD. He told me the same thing that there wasn't a fix at this time and that he would have to turn my problem over to the customer care team.He said that CCT would investigate my problem and that somebody from the team would contact me in two business days. It was more like six. He went over my problem with me and basically told me that the window was "DESIGNED TO LEAK" and it was a characteristic of my vehicle. This is the most ridiculous thing i've ever heard. He stated that since its a characteristic of my vehicle that their is nothing they can do to fix it. He stated that my truck has a trough under the slider that catches the water that leaks in and drains through hoses that run outside the vehicle. I have torn apart that back seat(short of taking out the seats)looking for this trough and hoses. Im not seeing a thing other than the housing for the cable and the rear window motor.I was just curious if anybody else has had this problem or something like it. Or any advice on what you think my next steps should be. I have already filed a complaint with the BBB and waiting to hear back from them. If I would have known about this so called "characteristic" I would not have bought the truck. Im a blue collar working man that has a very expensive truck. I sure as hell don't want it to leak.
Thanks For Listening
Matt Demmin
There's no way the characteristics of the truck is to leak water in the cab. And there is no reason for you having to look for the problem, the sliding rear window has been around for years and many don't leak including mine. Maybe you could try a different dealer.
+1 on trying a different dealer. Mine doesn't leak and there would be a real problem if it did.
Agree with the others....that response would be a "no go" in my book.
Take it to another dealership. Make sure you get everything documented from all involved in case you have to escalate things further up the ladder.
Any Updates?:dunno:
Yeah.... Sorry about not posting the update. I ended up taking my truck to different dealer. It turns out that 3 out of 4 seals were bad and they replaced all of the seals.
So far i have had no leaks and I had no problems at all with the other dealer and everything was covered under warranty. Thanks for all of the advice...
Good job Man! Thanks for the update. Glad to hear it worked out for ya.:thumb:
I have the same problem. Thanks for the update. I'll go to the dealer prepared
The dealer said that it's the seal around the extra brake light that is allowing all the water in. He is ordering the part and I will let you know if it works
I have a 2013 F-350 Lariat and I too have the exact issue. It leaks in heavy rains and in car wash. Why has not Ford addressed this issue as a recall. My dealer acts like they don't know anything about it and are not willing to fix it for free. I guess they just lost my business. I would like to find out what your findings were. At this point I will try and fix it myself instead of wasting my time and money. If anyone else has had this issue please respond. I will take off the brake light today and see if I can eleminate the brake light possiblilty with some silicone. Wonder does Ford ever read these forums?
2013 F-350 leaking slider
I too have the same issue and it sounds as if this has been an ongoing issue for all Ford trucks. My dealer acts as if they have never heard of the issue and says ford will not take care of it under warranty. They should because it appears to be a common defect. Anyway I will look at my break light to today and see if I can eleminate it from the possibility with some silicone. Then see what happens. If it still persist I will try another dealer because the one that sold me the truck can seal but can't fix anything. I guess next time I will buy from a dealer that has a good repair shop or more willing.
Administrator
a recall campaign for a leak that i have read about 2- 3 times ?
that's as extreme as it would be to ban someone for an accidental double post lol
1 - 13 of 13 Posts
