1 - 20 of 190 Posts
Bought this 2011 4-door loaded Lariat with a 6.7 Diesel engine that was highly touted as the best diesel truck ever.
I service the truck religiously and baby it. Never been in the mud, never abused. Driving to an appointment yesterday and the truck started knocking then violently shaking from the engine. I pulled over immediately and turned her off. Looked under the front of truck and 13 quarts right there on the ground.
Had the truck towed to dealer and today find out the 1st and 5th cylinder are showing nothing. They removed the oil pan and crankshaft is jumping around freely. The long block is shot. The short block is shot and apparently the turbo and all. The sympathetic diesel mechanic felt terrible telling me that the entire engine and components need to be replaced.
The damage: $24,233.67........ Although he can tell I immediately shut the truck down due to no evidence of blowback in the exhaust, he said it was a possibility that I could be required to pay another $3,000-$4,000 if the exhaust showed damage after engine replacement.
I have no idea what to do. This truck cost $60,000++ and is only 3 years old with 124,058 easy miles on it. I owe money on it still so I am at a loss.
Any suggestions? Should ford cover this basically totaled truck? I'm in the midst of the dilemma and need advice or help from someone not emotionally tacked with a $24,000 estimate.
My plan is to cover every site on the internet with this info and contact ford to see if they will stand behind the product. This truck has cost me thousands with the exhaust sensors going out time and time again while leaving me stranded on the side of the road. I will not rest until everyone is informed of this and Ford stands up to their mechanical workmanship failing. Any attorney interested, please contact me.
Vendor
Junk yard motor for around $5000 will probably be your best bet.
Ironically there was a recent thread on hear of why people hate the new 6.7's and are scared of them. And unfortunately your situation is why I will never own one.
Gonna subscribe to this thread to see how it turns out for you.
Have a failure analysis performed on the engine by an independent mechanic. Use the Ford Dealership ONLY if you feel as though you can trust them. Document everything. The root cause of the failure CAN be determined by a good analyst.
I would speculate that the engine suffered an exhaust valve failure that is all too common with the 11 model and early 12 model engines or it suffered a broken crankshaft that while not as common as the valve failures it does happen.
Poormanscat, thank you for the info. What would the possible outcomes or accomplishments be to make it worth spending $1600-$2000 on failure analysis? I will do it in a heart beat if it would accomplish some sort of resolution. I'm still in shock and new to a repair bill this steep so I apologize if I'm missing something obvious.
Where are you located?
Bummer, wish you were closer to Houston. I know alot of great shops to recommend there.
I dont know of any in Dallas off hand
Wow, i was told that 6.7 are the new 7.3. hmmm. subscribed to this, even though i own a 6.0 still want to see what comes out of this.
i know you asked if its worth the 1,600 to do the analisys, i would think it would be. IMO you have all the paperwork that shows the oil has been changed on time, truck has been serviced on time and the fail analisys comes back with a manufacture defect you have a case, if Ford dont stand by their product then grab a lawer. but if thats too much of a headache then grab a severly damaged same year truck thats been hit in the rear end, but front end looks good, swap the engine.
heres one in parrticular
http://www.copart.com/c2/homeSearch.html?_eventId=getLot&execution=e1s1&lotId=17278094&returnPage=SEARCH_RESULTS
heres others.
http://www.copart.com/c2/homeSearch.html?criteriaType=detailedSearch&returnPage=home&searchType=HOME&filterBaseLabel=Automobile+FORD&filterCode=&freshRequired=true&oSearchByType=Y&vehicleType=V&startYear=2011&endYear=2011&make=FORD&model=F250&titleGroupCode=&location=state&stateFacility=TX&zipPostalCode=&mileageRange=99999
and the rest of the truck part it out.
times like these makes you wish u had an extended warranty. good luck,
What good is grabbing an attorney going to do. Hes FAR FAR FAR past the warranty period. Hes almost double the mileage on the engine warranty
What dealer told you this info as well Im curious?
Especially the long block and short block comments. Thats sounds like a service advisor that doesnt know WTF hes talking about.
What hurts you as far as Ford covering anything is the fact that youre at 124k miles. The warranty is only good for 60k miles.
My suggestion is find a new shop as this one is attempting to take you to the cleaners.
Did you throw a rod?
Discussion Starter #16
I had the 100,000 mile warranty. Dropped a valve and crankshaft came loose or was bouncing (some specific measurement) causing irreparable damage the diesel mechanic said. Also told me the heads and/or injectors were damaged and probably the turbo, although he didn't see much blowback in the exhaust but couldn't promise me that it would be fine. 5th cylinder was quite? I think he said. Cylinder 1 was about to drop as well. Mentioned glow plugs being burnt or broke. Heck, I don't know what all this is but I do know what the repair ticket says it will cost. The truck was perfect with no unusual sounds or change of power, no smoke. No oil on my concrete drive that I had it parked the night before. I'm just disappointed and you would be too if your $60,000 truck was no good after just 3 years.
Believe me Jason. I would be pissed too. Theres no question about it. I didnt know you bought an extended warranty
LMK if you need a referral. You should be able to get a brand new Ford engine installed by a Ford master or senior master technician for around half that. It'll be at an independently owned shop though.
I have found that the best Ford diesel techs typically go out on their own and away from Ford corporate
1 - 20 of 190 Posts
