Hi
I have factory stock F450 172 SD Crewcab DRW 4x4 but would like to upgrade the tires and rims without changing the assemblies. I have seen American Force Rims with 35x17.5 DR 24LT Fury tires.
Question
1) Do you need to change the assembly to fit these tires and rims?
2) What is the best set-up for running on desert sand - more for camping than dune bashing?
3) What is the "largest" tire and rim set up you can fit with out changing the hub assemblies.
Thanks!
Question
Thanks!
