1 - 5 of 5 Posts
I am new to the forum.
I have owned several Fords over the years all gas motors, with no problems.
So in May I bought a used F450 4x4, loaded, 35k miles, very clean truck, etc. with ext. warranty (lucky). From a local Ford dealer here in washington state.
About 2 weeks ago I notice oil leaking from the rear of engine. So I just get in the truck drive it down to the dealer and told them to fix it. They said it would be a 5 day fix. Bedplate was leaking, the motor has to taken out of the truck.
Cab off job, then Ford dealer calls today, says we need truck through middle of next week. And I was thinking oh S*** the rods, pistons,or something major is wrong. The serivce manager says that your fuel pump is going out, You have a lot of suet build up in the intake and a lot of suet build up off your exhaust tips. I never even noticed a problem with power of mtr or fuel pump problem.Then he said to me that we need to tear down part of the eng to get to it, replace it and you will be good to go.
I am so glad they found the problem.:icon_ford: I am sure this is costing Ford a pretty penny. :crazy:I am just concerned about future use with this truck. I just bought it 2 months ago. I will always keep it serviced at this dealer oil, fuel filter etc.
Is there anything I should keep an eye on now that this has happened? thoughts?:)
Bedplate seal on my 05 was leaking too back towards the middle of March. Slide it in under the factory 5/100000 warranty. Dealer pulled the engine out instead of removing the cab. Had my truck for almost a week.
2008 6.4 oil leak
ok just bought a slightly used 2008 f-250 king ranch while washing and waxing i slide under truck and found a shock leaking,oil drain plug leaking and leaks from under the oil cover,and back by rear main seal, ok now im feeling great about buying a truck with 18000 miles ,i never owned a diesel before my 2000 f-250 never leaked a drop--- am i in for nothing but troubles and any comments i can give to dealer to ensure a one time fix would be appreciated
I purchase my truck in 9-7-2007, 08 F250 SD 4x4 ....I bought all of the ext/warranties. I have recouped all my money....granted I have had issues, my truck is stock and I keep it serviced. I would tell everyone that ownes one to keep real good service records and keep the truck stock. At this time I have 135K miles on my truck and have warranty coverage ..the 21 major engine componet warranty, at 117k miles the HPFP was replaced at no cost to me, on this repair Ford did send in a rep...to check the truck out before work was done.....
yeah the extended service plan (ESP) contract is much harder to get warranty work through. they constantly pound us for maintenance records then send out inspectors to look over the vehicle. i've had more than one injector claim denied from lack of recorded maintenance. they really should tell you that in the contract
1 - 5 of 5 Posts
