I am looking at 10in lifts for my f250. but dont know the difference between radious coilover and 4 link. Also whats the recomendations for the 2.5" spring spacer leveling kit in addition to 10in?
A radius arm lift uses bracket to drop the rear of the radius arms which stay in place. A 4-link completely replaces the radius arms, and coilovers replace the coil spring and shock with a single unit which has a shock with a coil spring made into it.I am looking at 10in lifts for my f250. but dont know the difference between radious coilover and 4 link.
I have a buddy running 40" tires on a 10 inch lift. I am planning on running BMF 20x9 or 22x9 what would be the best tire size. Im thinking 42's but 44's would be nice. whats the price difference between fabtechs 10" lift and a 12 inch like your running?The 2.5" spacer will work fine on top of the 10" lift. I've got a 12" with 2.5" spacer on top. If you do it make sure your shocks are long enough and go with the 4 link. It will ride better and work with the spacer better then the radias arm
