I'd take it out of the parts truck and then take the steering column off your truck and see how the 6.0 shift lever is attached and if you can simply unbolt or unscrew it and put the other one on. It might require the newer steering column because idk if the shorter one will hit on the 6.0 steering column.
Only way to find out is to try:nod:
