1 - 14 of 14 Posts
Ive been reading a lot on here and have some questions.
1. I heard with 2008s you have to get an extra module but I got a 2010 engine so do I have to worry about anything?
2. I have heard a lot of mixed things about viper but always thought they were they best?
3. What is the most reliable remote start that not too expensive? Autopage looks good?
4. Do these after market alrams use the factory horn or do they come with a louder alarm?
Thanks so much
1 yes you will have to use a antitheft module bypass that kicks on when the remote start activates it. it basically fools you computer by thinking you key is in the ignition and clones the security feature in the the key.
2 i am not a big fan of viper they are way to complicated for the average joe to put in the shop i work for i am the head installer and i hate doing vipers just because im not to familiar with them. i prefer compustar or cool start. the compustar is by far my most favorite even though they are still complicated they are an awsome remote start and i have never had unit go bad. as for a viper a customer brought one in he had tried to install and the unit was bad out of the box and best buy refused a refund.
3 you dont want to go to cheap on a remote start because it has to have a wait to start sense wire or the ability to kick the ignition and accesory wires on to get glow plugs warmed up on a diesel remember you get what you pay for and electronics are not a good thing to go cheap on.
4 most good quality alarms will come with a seperate alarm horn
also the security on these trucks are a little finiky i know on the 2010 they dont have a factory alarm disarm wire with the key if you lock it with the remote which is why if you hit the lock button on the remote wait a like 10 min and come back and unlock it with the key it will ask you to turn the ignition on. the factory remote and the keypad are the only problems with it but its not that big of a deal compustar units have an option that allows you to send a signal to the wires to disable the factory alarm if it gets set
I have a Viper which I paid a professional shop to install. It's a great alarm and I haven't had any issues with it. It has a lot of features and user programmable options. It even has a turbo timer for diesels. I also have the GPS feature with it and yes, I had to have a module installed like stated above to bypass the anti-theft chip located in the key.
how much was that?
probably close to a grand, correct?
I have a black widow alarm remote start that I put in myself. No other module was required. Everything came in the box for gas/diesel manual/auto install. It was straight forward once we had wiring schematics to do it. I chose to only use the siren rather than both horn and siren. It was not as difficult as I expected but hiding the wires and module was tedious! Lots of zip ties and wire loom. It also allows you to set your second delays for your glow plugs. Works like a charm!
Sent from AutoGuide.com App
I have a Viper 5704, so far so good except for cracking the screen on the remote. My only real complaint is that I have to sometimes hit the lock/unlock more than once before it receives the signal and sometimes it seems a little laggy.
Don't be fooled by the advertised range. This only applies if your parked in the desert with nothing taller than 2ft around you for miles. Mine will barely work from inside my local costco or grocery store. As with most TX/RX, if your under a metal structure your range will be greatly reduced. In most cases the range is more than acceptable.
how much was that?
About a grand, like the other post said. I will say though, my range on my remote is pretty good. Even if I'm inside a store or the gym, I can hit the remote start and my cold a/c is waiting for me when I get inside the truck. If it doesn't reach, I can always use the app on my phone to start it from anywhere in the world. :crazy:
I just installed the Viper 5904 with remote start.
1) Read and find all your wiring diagrams before starting off. I purchased a month subscription to Motorcraft's service manuals. It had everything I could have ever wanted once I figured out that I needed to use Internet Explorer to view anything.
2) There are some peculiarities about the remote start that will have you puzzled. The Ignition and Accessory Polarity wires need to go to a common +12v source. This was not very explicitly defined in the manual.
3) The viper 5901 install manual will work for the 57xx or 59xx alarms. The wires are the same color, but might be in different harnesses. Googling "Viper 5901 install manual" will give you a PDF you use to assist with the install.
4) SOLDER ALL CONNECTIONS
5) Pop out all the unused wires from the connections. I used a safety pin to insert into the connectors to get these out. Kind of a pain, but makes for a clean install.
6) Cut the wires to length after you determine the mounting location of the brain. This will keep you from having to zip tie a bunch of excess wire.
7) Use shrink wrap where possible. I even popped out some of the Ford wires from their connectors to slip shrink wrap over.
I can keep going, just post any questions. I can help with wire colors and locations.
The Viper XK04 module needs to be wired into the PATS module on the steering columns. If you use D2D on the module, you only need to wire up 3 more wires. The Tx, Rx, and Ignition wires. I mounted the module in the steering column plastic under the wheel.
The install will run about $200 at Best Buy and up to $600 from a certified installer. If you think about this, no good installer can have this thing installed, soldered, and heat shrinked in two hours. Best Buy quoted me two hours. I said, screw this. For that price I can buy another Viper alarm if I screw this one up. Took me about a week working on it a little bit at a time. Once you commit to cutting the ignition wire (White/Blue) for the starter kill/remote start, the vehicle will be down until the rest of it is finished. Save the starter kill/remote start for last when you have the most time.
Notes:
-You cannot shut off your courtesy lighting/stereo (that turns off when the truck is off and door is opened) without pulsing the door triggers. Hook a +12 pulse when armed to one of the door trigger wires.
-Don't use Domelight for the trigger. Grab the four door trigger wires at the SJB. If you use the domelight, the alarm will indicate a door open when you arm it since the domelight stays on for a little while. Also, if you touch the dome light buttons on the door keypad, it will set off the alarm. These were the biggest pain in the butt wires to get since they are up under the pass dash at the top of the SJB.
-The violet/white brake wire (to shut off remote start if key is not inserted) must be grabbed at the brake switch connecter on the brake pedal. There are about 10 other violet/white wires all over the dash and driver's side sill (by driver's seat). There are even more if you count the violet/gray wires that look exactly the same in certain lighting.
-Diode isolate door triggers.
-Diode isolate all grouped wires
-To have driver door priority unlock if you have remote keyless entry already, you must pickup these wires at the SJB (pass junction box) or install relays.
-Buy the handheld bitwriter programmer. It's about $60 on Amazon, but you can really tune the system better than with the push button/chirp method.
-You don't need a tach wire for the remote start. The 2008-2010's have over crank protection. Just disable the tach feature in the alarm and set the crank time to about 0.6-1.0 seconds. More maybe in the winter if needed.
-Lastly, you cannot hook the Viper's up to your door keypad to disable when you type in the code. Viper has no wire to disarm the alarm. You can only use the remotes. Some alarms have a disarm wire that can be used with a relay to disarm when you type in your keypad code.
Good luck!
The Audiovox site is nice. The12volt.com is better. The Audiovox wires were a little different than I expected. For instance, no second Auxiliary was needed. Also, be careful as the PATS wire and the later 2008 second Aux wire were listed as the same color. Ended up being the PATS wire in the steering wheel wiring harness.
UPDATE: I have had my viper for two weeks now. Other than turning the cranking time up from 0.6 seconds to 1.0 seconds to eliminate an occasional false start, the thing has been working great. I ended up setting the remote to lock itself after 30 seconds so I couldn't accidentally start the vehicle in my pocket.
I installed the shock sensor on the steering column firewall bracket. Works great for opening the hood or kicking the bumper. Doesn't do much for hitting the truck body with my fist. I don't want it too sensitive since we get a lot of thunderstorms here in Albuquerque. In fact, it hasn't been set off once by any. I did forget to disarm the alarm when i shut my hood the other day and the alarm starting going off with the horn. It was obnoxious and the keys were in the house. Probably drove my neighbors crazy.
When they came out to ask about what alarm I got, I told them I had a recent vehicle break in. They were stunned as we live in a nice neighborhood. The neighbor was curious about the viper and I showed him everything it could do. He said I was an over achiever for installing it myself. I kindly told him that I won't let anyone work on my vehicle unless I absolutely can't do it myself.
I probably wouldn't announce on a public forum that you have the anti-theft disabled on your harley truck.
what ever brand you get make sure they have been around for a while. also make sure they have a lifetime warranty. I had one that had been around for a while. the key fob went bad. got new one under lifetime warranty. then the brain went out and the company had been bought out by someone else. don't know who. end of that. did have it for about 10 years. have a marksman on my 08. no prob for the last 5 years.
1 - 14 of 14 Posts
