1 - 13 of 13 Posts
I recently purchased a 07 F350 with 163000 miles that has been BulletProofed. Before buying I had a Diesel shop go through the truck and they found no issues.
While doing a final inspection of the truck I tested the 4 wheel drive with the seller. Everything worked fine but it was obvious the seller had not used the 4wd in a long time, if ever. After buying the truck I started to notice a rubbing/clunking/vibrating noise from the front end on the way home. I thought the hubs may have not unlocked. But I was able to spin both front U-joints and the front drive shaft with no issue. After getting home I lubed the hubs through the vacuum lines and I greased all the U-joints. None of the U-joints appear to be shot and I could not find any sign of the noise.
The noise starts when I press the gas from a stop and increases as I speed up. When I let off the gas it initially stops but then comes back. I can feel resistance as well when the noise starts but then the resistance goes away. When I make sharp right turns the noise increases and when I make sharp left turns it goes away.
I have put the truck on the rack and all the suspension and wheel bearings appear to be fine after shaking the wheel from 12 & 6 and from 3 & 9. With all 4 wheels off the ground we put the truck in 4 wheel drive and only the front left wheel turned. We removed the right hub but it appears to be fine and moves freely. I have not had a chance to remove the left hub yet.
Does anyone have any idea what the problem could be? Thank you.
Nothing in the hub that your lube will help in that spot -- what will happen is the lube you put in will be drawn into the vacuum pump and may cause damage there
I suggest removing the hubs and clean them out, then apply some fresh lube to the moving parts
The locking hub works like an ink pen -- push one time, 4x4 -- push again , free wheel -- only with vacuum
the vacuum from the solenoid is pulsed to make that happen
may want to use a hand vacuum and test the lines heading to the hubs for leaks
sounds like you have a wheel bearing heading south -- turn slightly one way and it gets quieter - the other way louder
you may not feel the slack in the wheel
Double row ball bearing -- the old narrow roller bearing was better -- still older tapered bearing was best, my old '79 has those -- tough as nails
Administrator
not sure we are talking the same thing here ??
was refering to the spindle/innermost unit bearing bearing ;-)
i never see people with a sealed spindle bearing failure ,,
the old needle bearing types were more problematic IMR
IMR = in my reading lol
Discussion Starter #11
Last night I lifted the front end off the ground, locked both hubs, turned the wheels all the way left and right, while rotating the wheels and I could not hear any new or strange noises. I greased the U-Joints and noticed grease coming out between cap and body (pictures attached of both left/right). I could also hear air escaping from where the grease was coming out. Not sure if that is normal or not. There is also a little play, not much at all from the right/passenger shaft where it meets the U-Joints.
I took the truck for a drive, although better, it is still making the low grinding/clunking vibration noise. I am almost positive it is coming from the right/passenger side. When I make a hard right turn it gets worse. Any ideas as to what to do next? Thanks!
Discussion Starter #13
I’m at a loss for exactly what this is. Does any one have any suggestions?
Can I replace just the bearing and not have to replace the whole wheel hub/bearing assembly?
1 - 13 of 13 Posts
