· Registered
I just bought this truck and I was wondering if the upgraded sct fitting, and the upgraded oil feed lineand drain tube are already on my truck. Also, it looks like there is a coolant filter on the truck already from the factory.
· The Silent Service
The coolant filter was not a factory installation, that would have been added by the PO. Which brand is it (should be printed on top) and I'd get yourself a new filter for it.
As for the SCT fitting, you'll need to check your trucks service records.
The turbo feed and drain lines do not require an update with the '07 trucks.
