Year:2007
Make:Ford
Model:F250 Super Duty Crew Cab
Mileage:136072 M
Transmission:Automatic
Engine:6.0L
Trim:Lariat
2007 Ford F250 Lariat Superduty Crew Cab Short Bed 4WD 6.0L Diesel
Selling my Truck.
I don't use it enough. It just sits.
Message for questions.
Here are the upgrades:
Edge Tuner
8 inch Pro Comp Lift with Dual Front Coilovers
1 Up Offroad Traction Bars
Custom Front and Rear Bumpers with Swing out Tire Carrier and LED lighting
Front and Rear SmittyBilt X20 15.5k Winches - yes, i said Front and Rear!
Synthetic Rope Lines for Winches
Factor55 shackles
WARN 16k DRing Shackles
Custom Tow Hitch with Support Bars
STEP bars
SnugTop Topper
AmeriHood custom hood, Painted to match
Sprayed on Bedliner, which has also been sprayed on the Rocker Panels, Door Sils, Step Bars, Fender Flares, and the Bumpers.
Engine has been studded and EGR Delete
Odyssey Batteries (the best out there)
Upgraded Engine Wiring (usually called the Big 3)
Custom Alternator by Mike Singer
Red Head Steering Box
S&B Air Intake
Custom Aluminum Blue Intercooler Pipes
37 inch tires and 20 inch wheels with matching spare on Tire Carrier
Hi-Lift Jack
3x 5 Gallon Fuel and Water tanks on Tire Carrier.
Square Mirror upgrade
BushWacker style Fender Flares (with sprayed on bedliner)
Custom Front Grill
50" LED CurvedLightbar
Weigh Safe Tow Hitch
LED lighting for Tail and Headlights
All weather floor mats
Tinted Windows
CompuStar Alarm with digital Remote
NOCO Genius 10A charger
PowerStop Z36 Brakes - slotted/drilled Red Calipers
The Bad:
Cruise control is not working or Audio control on steering wheel. Dealer replaced steering wheel when I bought truck 7 years ago, I think he installed the clock spring wrong.
Air Conditioner does not work. Maybe needs recharge?
Lights on the bumpers and roof still need to be wired to a switch as well as the solenoids for the winches.
Front windows have trouble rolling ip and down since the CompUStar alarm was installed. I was told the window tracks need to be greased to create less resistance for the alarms electronics.
Driver's seat adjust needs to possibly have switch replaced, it does work, but the forward doesn't activate unless held for a few seconds.
ABS light comes on and off. A mechanic told me that the sensor on the rear diff may just need to be pulled and cleaned.
The EGT sensor on the Tuner either needs to be cleaned, shirt in the wire, or needs to be replaced. It gives intermittant readings.
Passenger seat has rip in it. Can replace cover for about $65.
Video monitors in headrest may or may not work, I have never tried to use them and they were not hooked up when i bought the truck.
Driver's front blinker light bulb needs replaced. It works, but the driving light portion of it does not work. It is a switchback LED.
The canopy needs the locking brackets installed (have the parts) as the old ones have broken.
That's pretty much it, just minor problems. It runs and drives good!
I am firm on $23,000
Selling my Truck.
Edge Tuner
Factor55 shackles
STEP bars
SnugTop Topper
S&B Air Intake
Hi-Lift Jack
Custom Front Grill
Tinted Windows
The Bad:
