I just put new batteries in it checked all grounds and fuses.....I have a horn parking lights dash lights and that is all..... nothing when I turn the key.....before I go trace everything out I’m hoping someone has run into this and it’s something simple🤞Thank you guys.....update I have found after doing some tracing that I do not have any volts at the ignition switch under the steering column
