1 - 5 of 5 Posts
2006 F450 6.0L Powerstroke engine stalled while driving down road. Will not re-start. Injector Control Pressure sensor only reading 72 psi. Is it possible Injector Pressure regulator at fault?
Then you have a High pressure oil leak somewhere.
Have you replaced your dummy plugs, Stand pipes and STC fitting yet?
Question on Injector Pressure Regulator first, so if regulator is stuck wide open, what pressure would I be reading if no leaks are in system while cranking? I have not opened up cover to high oil pressure pump.
1 - 5 of 5 Posts
