FS: Black 2006 F350 CCLB SRW Lariat FX4 Lifted - $20,000 - 121kmi - Houston TX
Northwest Houston, Texas Area
More Pictures: F350 LB CC SRW $20,000/obo Houston TX - Imgur
Note: All pictures above are from before work detailed below was done. These are the pictures I originally bought it from. I'll take some of my own shortly, but she really needs a bath, Texas Pollen season is horrible. I have only put on about 6,000 miles since these pictures were taken.
Asking $20,000
121,XXX Miles
Non-Stock Stuff:
Recent Repairs/Maintenance:
Modifications done:
I run Rotella T6 Full synthetic oil with Rev-X Oil additive to keep the injectors and oil system functioning perfectly.
I add Opti-lube XPD Fuel treatment to every tank of fuel.
Maintenance and Repair paperwork included.
Multiple bottles of Evans Coolant Included.
Replacement Coolant Filters Included.
All said and done, I bought it broken for $~19000, knowing it was in massive need of repairs. I put in over $9000 in repairs and upgrades into it.
I don't drive it enough to justify keeping it. It sits in my driveway more often than not, it deserves to be used! Also, my Home's foundation has cracked, and I need the cash for foundation repair
Foundation Pics:
Photo Album - Imgur
Feel free to post here if you have questions, etc. I'll answer them as I can.
Asking $20,000
121,XXX Miles
Non-Stock Stuff:
- 8"? Lift Kit (Installed when I bought it)
- HID Headlights (Installed when I bought it)
- Bluetooth Capable Stereo and Aftermarket Speakers (I installed)
- Remote Alerting Alarm system with remote start (I installed)
- New Radiator & Coolant Hoses
- New Oil Cooler
- New Coolant Reservoir
- New Alternator
- New Belts
- New AC Compressor
- Lots of Front end work
- Transmission, and Transfer case serviced and fluids changed.
- New Tires all the way around
Modifications done:
- Evans Waterless Coolant system - 0PSI Coolant system.
No water, coolant boiling point of >350 degrees, no vapor pressure in lines, only pump pressure. - Coolant Filtration system installed
- EGR System removed (Block off plate in uppipe, will still pass visual inspection)
Prevents EGR System Failure leading to head gasket failure from coolant leaking in from EGR. - K&N Mini Maxx Tuner installed, provides 4 levels of tuned power, also monitors all electronic sensors on the vehicle for problem prevention.
- EGT Probe Installed
- Fuel pressure regulator upgrade
- Fuel pressure Gauge
- Boost Gauge
Foundation Pics:
Photo Album - Imgur
