1 - 8 of 8 Posts
While installing a new transmission from ATS someone ran over the tranny dipstick that was next to the truck with the dang lawnmower. It wasn't me btw. I found the remains. I was able to straighten it out and the tip is still attached. If I'm lucky it only busted off the cap end. It is the same length as the oil dipstick. Can someone measure thier transmission dipstick please, and let me know the length? I've looked all over online to find a part number or a replacement with no luck. I found 7.3, 6.4, and 6.7 but no 6.0 other than the van models and their tranny tube is a different length and bent differently so I dont trust it to check accurately.
Here you go
Thank you, I had looked over that listing since it said Engine Oil Dipstick. I see in description it's for the tranny. Great looking out 6. Thanks
This isn't going to work, it's just the engine oil dipstick. It only has min/max marks nothing for hot and cold fluid checks. The add had misinformation regarding it being for the transmission. Can anyone compare the length of their engine oil dipstick to the transmission fluid dipstick?
1 - 8 of 8 Posts
