It probably has a loose injector or a compromised copper gasket on the bottom of your problem injector.
You can remove the fuel filter and tower, fill the canister half with fuel if it isn't already, crank the engine with the jumper cable on the passenger fender and see if there are any bubbles coming up from one of the ports to the heads.
The FICM is bad.
The FICM is bad.
