Likely to have an injector dumping fuel into that cylinder.
Thank you would you happen to know what I need to stop that leak?Likely to have an injector dumping fuel into that cylinder.
I agree, one drip of automotive fluid will not kill you, and is a good way to identify the fluidjust taste it
My 2006 f350 just started leaking from here. I’m sorry if these pictures aren’t good enough but I can take more if needed, it’s dripping a clear fluid. Please any help on how to fix this issue or
The fuel rail plug on the back of the head is leaking. It has a o-ring on it that has failed.My 2006 f350 just started leaking from here. I’m sorry if these pictures aren’t good enough but I can take more if needed, it’s dripping a clear fluid. Please any help on how to fix this issue or any advice would be great thank you!! View attachment 771080 View attachment 771081
Good call...forgot about that! Should be able to see that plug with a mirror to confirm, right?The fuel rail plug on the back of the head is leaking. It has a o-ring on it that has failed.
On a side note - @kaya it's good to see ya back! It's been awhile!Oooooh that's a fun one.
Just check to make sure there's nothing in the valley first. A leak there could drain back.
