First, I would make sure that the exhaust downpipe isn't rubbing against the firewall.
If you want to check the turbo:
Acceptable tolerance is measured in axial play (in and out) and radial play. Axial play should be no more than .091mm (0.0036in). The radial play tolerance is 0.5mm (0.02in)
