I am having an issue with my 2005 F350 with about 150k miles. I had been using it maybe once or twice a week for the past couple of months. Last week I went to use it, it started fine, but after driving for about 100 ft it started making a really loud noise and having a rough idle (similar to a gasoline engine misfiring). So I drove back home and shut it off. About an hour later I started it back and had the rough idle. I let it warm up to see if it would still do it at operating temperature and it still did. I suspected it was a bad injector. I believe the previous owner replaced 3 of them and the rest are the original injectors that came with the truck from the factory. They also replaced the FICM and a few other sensors after the truck was stolen and several parts were removed.
The CEL was not on. I used Forscan to pull codes and it showed some glow plug codes, a couple of ICP codes and a cylinder 4 contribution code. I deleted the codes, and restarted the truck that day and few times in the next few days and the codes that came back are the glow plug codes and 3 ICP related codes. The cylinder 4 contribution code did not come back, but the engine is still having the rough idle. I have also ran the KOEO injector buzz test and I can hear all 8 injectors clicking each time I run it. However, if I turn on the engine, the issue is still there. So that leads me to believe it is not an electrical issue but a mechanical issue with one of the injectors. The FICM voltage stays at 48v when running, the HPOP psi reading is at 800 at idle, the IPR % is at 31 at idle. That leads me to believe it is not a FICM or IPR issue. I disconnected the starter wire and jumped it to the positive terminal and the engine cranks fine and consistently, which leads me to believe it is not an engine compression issue. A couple days ago I started the engine, and unplugged the ICP sensor and still ran rough, I did not see a noticeable difference in the way the engine ran.
These are the ICP related codes, but it did not make a difference when I unplugged it.
P2284 ICP sensor circuit range/performance
P2288 ICP too high
P2623 ICP regulator open
Please take a look at the video of the truck idling fine and then idling rough and let me know if you think it might be an injector (or more than one).
I don’t have $3200 to spend on replacing all injectors so would like to find which one is causing the issue and only replace that one. I have called around and none of the diesel shops offer a mobile service to come do a diagnosis. They have all asked to tow the truck to their shop or drive it there, but I do not want to risk driving it like this. I would like to replace the injector myself (this is my first diesel, but I am “mechanically inclined”) so I would like to know which injectors specifically need replacing so I can do the labor myself. From what I have read the best option is a power balance test using the IDS software. Is there an alternative to the IDS software? I read about AutoEnginuity, but it seems their power balance test is not as reliable as the IDS is. If I cannot find a place with the IDS software, what options do I have?
Is there a way to physically unplug each injector at a time and run the engine to see if it makes a difference, or can they only be unplugged after removing the valve covers?
Is the only other option to remove all 8 injectors and take them to get tested to see which one is bad and then replace? It seems like a lot of labor.
Any feedback would be greatly appreciated as this is my first diesel and am still learning a lot about it.
Here is a screenshot of TorquePro with the engine running rough.
P2288 ICP too high
