1 - 5 of 5 Posts
I have a 2005 f-350 with the factory Upfitter switches. I am not getting any power to the wires under the hood? When I flick the switches in the cab to the ON position the little light on the switch turns on while the truck is running! I have checked the fueses and they are all good the relay is there! am i missing somthing?
Any help would be great!!!
Thankx
Those are not the wires that come from the upfitter switches!
The upfitter switch wires are directly behind the interior fusebox. The wires under the hood are called "pass-through" wires because they are just extra wires that go through the firewall that you can use for whatever you want. The other end of the pass-through wires are also just behind the fusebox.
You can connect your upfitter wires to the pass-through wires and that will let you hook up to them under the hood.
there is wires that come off the back of the interior fuse panel that connect to your switches. those connect to whatever you want them to
1 - 5 of 5 Posts
