1 - 8 of 8 Posts
It occurred to be that that Dana 60 on the Ex hasn’t changed too much over the years.
If I wanted to adopt new 2005+ 18” wheels for my Ex, rather than buy spacers, couldn’t I just swap the hubs, carriers, and brakes from a 2005+ truck onto the older axle?
The same thing goes for the Sterling in the back. I think I might just need the new bearings,hubs, and brakes.
Thoughts?
Except the steering knuckle, most of the rest of the parts will need to be replaced eventually anyway.
The reason for the 2" spacers is the 05+ axles are about 4" wider than the 99-04s. So even if you could swap all that stuff you would still need spacers.
Ah -- that makes sense. It was trying to think of a way to use the newer axle, but keep the leaf springs. If the new axle is wider, then there's no point. Is there any 2005+ front axle variant that uses leaf springs?
You know -- leaf spring perches are easy enough to install. And, 05+ F250 front ends with 3.73's are all almost falling out of the trees. Same with the rear ends, and some of those have e-lockers.
One day, I might just try to cut that coil spring garbage from an 05+ front axle and put my own perches on there. I don't really want to run spacers because that messes with the scrub radius of the tires -- and that's rough on tires. I suppose for now I'll just run what I have -- there's nothing wrong with it.
Why are you trying to keep leafs up front? I have a set of axles out of a 15 that are going under my 05 Ex. Axle width was one reason, increased turning radius from coils up front was another. There were other reasons...
There’s not much difference in ride quality between the leafs and coils as far as I can tell.
If I change over to coils, I have to fab and attach the frame reinforcement gussets that sit behind the engine cross member on the 05+ trucks. Those are required to prevent fatigue cracks and frame tearing at the area around the spring perch. Doable - but I think I’d have to take the body off and that’s a buttload of work.
Welding on the spring perches to an 05+ axle gives me the ease of keeping the leafs, and the benefits of the decreased turning radius, bugger brakes, and wheel offset of the new style axles.
Administrator
there’s not much difference in ride quality between the leafs and coils as far as I can tell
that's not what most folks who moved to a coil from a leaf setup say and improved turning radius
Discussion Starter · #8 ·
Just my experience. If there's a difference, I can't really tell.
I get it -- there should be because of interleaf fiction and what not, but I can't feel it in the seat of my pants -- or at least not enough to justify the work. But -- maybe it'll be worth it if I can figure out the gusset problem.
I want my frame to survive more than just trips to the grocery store.
1 - 8 of 8 Posts
