Hi guys. I have a really odd issue. I ordered some new headlights from Ford to replace the yellowed ones I have on my 2005F250. Everything matches us perfectly except the turn signal socket. It is rotated and the post holes are slightly different as well. I can get my stock bulb holder in it with some struggle but the bigger issue is that the bulb socket when tightened ends up facing the wrong direction and hits on the frame when I install the light. The part numbers are the same and everything. My original is the dirty grey one in the pics. Has anyone run into this? I would think this headlight would be the same from years 2005 - 2007.
