Hello everyone, I would appreciate your help and input regarding my 6.0 Rebuild.
I am looking to do a reliable yet enjoyable build
I have compiled the following list:
1. Full Engine Gasket Set
2. Engine Oil Cooler
3. Stand Pipes / Dummy Plugs
4. (6.4) Push Rods
5. Injectors
6. Glow Plugs
7. Low Pressure Oil Pump
8. Water Pump
9. Thermostat
10. Head Studs
11. Complete Idler & Pulley Set
12. Serpentine Belt
13. AC Pump
14. Resurface Heads / Weld Fire Rings / New Injector Cups / New Injector Seals
15. Replace Front Main Seal & Rear Main Seal (Comes in new Gasket Set)
16. HPOP & SCT Fitting
Please add your input on what you recommend I should also replace/update and with which company I should go with to buy the parts listed above.
If I have missed anything please add it below in comments
Greatly Appreciate Your Time!
4. (6.4) Push Rods
5. Injectors
6. Glow Plugs
8. Water Pump
9. Thermostat
10. Head Studs
12. Serpentine Belt
13. AC Pump
