I have a 2005 F-350 6.0 liter diesel crew cab. I've started to notice steering problems recently (66K miles) which happens intermittently. Almost feels like very low tire pressure, loss of power steering, pops to left and to right when trying to drive straight. This has happened 3 times in the last week and will go away after a few minutes. Steering fluid is full. Any ideas what could be causing this?
2 Grand for ball joints, wow. I just replaced mine myself two weeks ago, took like maybe 2 hours. Mine was making a poping noise over bumps and would sometimes feel like the power steering wasnt working. Now its fine. I 2nd the ball joints.
You can also test them by jacking up the front of the truck and put a pry bar under the front tires and pull up and down. This will tell you if there is up and down slack, then while it is up you can shift the tire side to side to see if they are loose. It also helps to have some one under the truck to watch the movement of the joints.
