I came home and plugged the truck in last night. I got a wild hair to look in the passenger wheel well and i saw oil on the frame. Sure enough the charge air tube from the turbo is leaking at the intercooler. There's oil on the innert fender under the hood and it seeped onto the frame rail. Should I clean the boots and tubes and retorque? Or should I pull the turbo and take it in to get new seals? Anyone had this issue? I also have the metal tubes on both sides of the intercooler. The turbo was also pulled a month or so ago to clean the veins and the hot side housing of the turbo.
Max
Max
