Sorry guys I’m new here if I’m not doing something right I have a 6.0 with a rough idle and no power has new ficm new fuel filters I have done the fuel bubble test no air getting in fuel filter housing injector electrical test checks fine getting a bunch of codes
Did you clear the codes after installing the new FICM?
Are all the FICM connectors firmly plugged in?
13V on the battery would not set the P0562 code. Is this an old code?
What are FICM VPower and LPower?
Has the FICM relay ever been changed out?
So you were right most were old codes I cleared and got a misfire on cylinder 3 and ficm in capability and all the glow plug codes so I did injectors on pass side (which a diesel shop was suppose to do 3 of the 4 last week) turns out the there was 2 pure power injectors and 2 that just say reman and they left the 2 hard to get to t30 bolts finger loose so I went ahead and did all 4 on that side runs much better but also still a very small miss I’m going to do the driver side tomorrow
