1 - 20 of 26 Posts
2004 5r110, 3rd to 4th shift problems
hey guys so i got a big, semi big, small (not to sure how severe) problem on my hands. Over the last 10,000 kms or so i have noticed that my truck is starting to sort of slip when shifting from 3rd to 4th, and maybe a little bit on other gears a bit but not as noticeable. WHAT i mean by slip is when it shifts, it will either hold the gear extra long and then hammer into 4th, or it will shift rpms will raise for a second then grab 4th. Truck has 140,000 kms (85,000 miles) and i like to drive it hard, very hard.
How big of a deal is this? like can i limp it or should i address it immediately?
Is there a cheap fix for this or no?
Im thinking about just buying a used tranny with lower kms for $800 and using that until i eventually get a built tranny. Used tranny will come with transfer case as well. but if i go this route ill need a little help as in DIY write up, im good with wrenching but some pictures and directions to follow would be helpful.
Been reading a lot about the Go-Go soleniod, would this help at all or not really.
Also when i retune my truck and it has to relearn the problem is way way more evident.
Also Also, truck sort of feels like it is shuttering a bit in fourth, might be tranny, might be a ujiont or rear diff i dont know but only really evident in fourth. might just me be over reacting when i feel anything while driving but seems like its there.
thanks for any help i have seen lots of posts about this but none have really solved anything. hopefully we can get these issues cleared up for everyone in one location
steve :icon_ford:
BUMP :bump:
:help1: Come on guys someone has to be a semi expert on these trannies :noteworthy:, i know theres lots of guys out there with problems like this.
steve
Could be a number of different things, first thing I would do would be to scan it and pull the codes.
the next three things I'd do when diagnosing this would be to check the solenoid (if it threw the code), check for dummy plug damage/leaking and then check the clutch packs and steels to see if they are burnt up.
This is actually a common problem of our transmissions. Its called the 3-5 flair. Its hard to understand at first but our transmissions actually have 6 forward gears and an overdrive. Under normal operating temps and procedures your trans will shift 1-2-3-5-6. When it is extremely cold out side it will shift 1-2-3-4-6. Sometimes under a hard acceleration while cruising it will downshift from 6th to 4th.
As for the flair between the shifts, if you have an SCT programmer you can up the line pressure percentage and that will help. Or, I believe that the GOGO diesel solenoid is another fix for it as well. I have this issue but just increased the pressure a little and it is not that noticeable now. Not to sure how the gogo solenoid is working for folks.
^^^ From the posts I have read, this guy is a tranny guru :thumb:
Pull codes at dealer or will one of the $200 scanners show anything? no lights are on the dash.
Where exactly is this Dummy plug? and to check the clutch packs and steels wouldnt i need to take apart the whole trans?
been doing about 5 hours of research and came across some very usefull threads on other forums and what not.
I bought my truck with 100,000 km (60,000) miles it now has 140 km (85000 miles) not sure of the previous history, am i safe to drain and put the go go in, change filters and refill or could i cause some harm by doing that?
Pretty much identical to my problems:
5R110 solenoids....trans Q's - TheDieselGarage.com
A huge thread on the .ORG also same issue:
http://www.powerstroke.org/forum/general-6-0l-discussion/227983-fixing-3-5-shift-flare.html
A Good way to change the fluid:
http://www.powerstroke.org/forum/6-...sion/169557-how-get-more-than-8-7-quarts.html
A huge amount of info on the torqshift:
TorqShift Transmission - Information and Troubleshooting - Ford Truck Enthusiasts Forums
A thread about how to change the DD soleniod:
Torqueshift Solenoid replacment - TheDieselGarage.com
this is all for now, should have done more research first but after about 15-20 mins i still hadnt made any progress.
steve
Made a little vid doesn't seem to bad???
Still going to do go-go
Wondering still if it is ok to drain tranny fluid if I don't know if it's been done in the last 85,000 miles??
And my final question what could be causing my truck to feel like its pulsing a tiny bit, feel it most at 25mph but sometimes feel it at 60 mph?? Ujiont??? Could it be tranny?? Steering ****??
Thanks guys steve
^^^THIS!!!
I also started having issues with tranny shifting before. I bumped up the line pressures to 10% on every gear except for I put 15% for the 3-5 shift... Problem is gone.
GOGO is also another option. BUT I would do something before driving it more and killing it.
Also, change out that fluid and filter!
i have 100 percent faith in the gogo direct clutch solenoid it worked for me and i have the exact problem .......its only 150 and it works i love it
steve6L that sounds exactly the same as what mine was doing starting around the same milage as what you have until 206000km. that was when i started checking into the gogo at some local shops only to discover that would be a waste of money. 3 days later i barely drove it into the transmision shop for a $5000.00 new heavy duty rebuilt tranny with billet torque converter. ouch would rather have only had to spend a little on the gogo but now i shouldnt need to worry this tranny should handle any crazy amount of power i throw at it. sorry to kick you in the knees but i would either start looking for a rebuilt or get it done before you grenade it like i did. it would only have been around $2000 to rebuild heavy duty before it let go.
Discussion Starter #13
Where abouts in Canada are you? What tranny shop?
Discussion Starter #15
Coincidence I think not :p so what parts do they put in for 2000?
he said heavy duty friction plates check all solenoids and replace if necessary check the pump, and a triple billet tourque converter. he is really knowledgable and easy to deal with, he does LOTS of these torque shifts and is not scared of them like some shops!
Discussion Starter #17
Oh I thought you meant 800 hp heavy duty I'm only building it once does he do transfer cases too, I'll have to pop by there tommorow
i belive he does T cases as well. if you stop by and tell him what you want to push for HP im sure he can build a tranny to stand behind it. I have pretty much the same mods done to mine and told him I'm not done yet, he said this HD tranny will hold up! he only likes to build them once on our dime then its on his dime if we can blow them up in a year! haha should be fun trying to spend his $$ its on 149st and 120Ave little shop that does lots of buisness!
Discussion Starter #19
I'll have to see if he can build a better tranny then nadp for $6000
I dont know about better but the same and I could almost guarantee it will be cheeper than NADP. I also had a quote from them and Hitesh just laughed and said they like to take peoples money for no good reason, they both get the parts from the same place same parts so you will laugh when he tells you his price for the same build, I know i did, and he just finished doing my tranny so that will tell you who had a better price. I like my toys but I also like my money in my pockets too!
1 - 20 of 26 Posts
