I am regretfully selling my 2003 F250 XLT FX4 6.0 Crew Cab Long Bed. The truck has 133k miles on it but has only 16k miles on a completely rebuilt/bulletproofed engine. The truck has a branded manufacturer buyback/lemon title and from what I can tell by the carfax report is that Ford bought this truck back in 2004 with 11k miles on it.
This truck is absolutely solid and has ZERO leaks. I'm looking to get $16,500.00 for it. Since I have owned it, it has been meticulously maintained and no expense has been spared. The truck is located in Reno, NV.
Complete Engine Rebuild in April 2010 at 117,400 miles. (It had blown head gaskets)
-engine was disassembled to bare block
-block was cleaned and cylinders showed good factory crosshatch
-shortblock was assembled with new rings, main bearings, cam bearings, and gaskets
-heads were machined flat with .006" removed, valves grinded, new valve seals
-turbo was cleaned and checked
-intake was hot tanked
-black onyx head gaskets installed
-arp head studs installed
-all new gaskets and o-rings throughout
-injectors re-o-ringed
-sinister diesel egr delete installed
New Parts Listed Below Were Also Installed (brand new parts):
-High Pressure Oil Tubes
-Oil Cooler Assembly
-HPOP screen
-ICP Sensor
-IRP Sensor
-Cam Sensor
-Updated Oil Drain Tube
-Water Pump
-Belts
After the engine was done the trans was flushed and a new inline filter was installed. The fuel filters were also replaced.
The truck is moded with the following:
-ARP Head Studs
-Black Onyx Head Gaskets
-Sinister Diesel EGR Delete
-Dieselsite Coolant Filtration System
-MBRP 4" Stainless Turbo Back Exhaust System
-Mag-Hytec Rear Diff Cover (running Amsoil 75w140ep gear oil)
-Zoodad Mod with Screen
-SCT X3 Programmed with Innovative Tunes
-Edge Insight with Edge EGT Probe and Dash Pod
-2008 Center Console
-Full Tinted Windows
-Viper Model 3002 Alarm (can be upgraded to remote start)
-Leer Camper Shell with opening sides
-18x10 Mazzi Hulk Wheels
-35" Nitto Trail Grapplers (LT295/70R18) 10k miles on them
-Go Rhino Dominator III Full-Length Steps
-HPOP screen
-ICP Sensor
-IRP Sensor
-Cam Sensor
-Water Pump
-Belts
-ARP Head Studs
