1 - 5 of 5 Posts
As I pulled into my driveway my truck started missing. I shut it down then tried to restart it - no luck.
Put the truck on my lap top with forscan. The readings while cranking were: FICM in sync , FICM voltage 46.5 to 47.5, IPR% 50.3, IPR pressure (assume this is HPOP pressure) 1557 psi, fuel pressure 55 psi. What do I look for next????
Post ICP voltage for KOEO and when cranking. Also, post the cranking rpms.
ICP voltage KOEO .25 KOER 1.79
Cranking RPM sorry I didn't record it but it was turning over at a very high rate. As fast as the starter
Could go with the batteries charged up.
Bubbles in the fuel bowl?
Can also "run out of diesel" at a quarter tank because of a bad fuel pick up.
1 - 5 of 5 Posts
