5yr ford tech here. i dont do much diesel work... well until now.
im now the owner of a 03 6.0L
hnoes:
i bought the truck knowing it had low hpop pressure. i hoped it was a ICP/IPR problem, but its not.
Leak tested it earlier and its the pump. i have light air pressure coming through the turbo feed line. 120psi max on cranking to boot.
So heres my question(s).
its got 258k miles. ICP harness looks factory, no oil seepage.
FICM is a reman.
Its suppose to have an EGR delete, but i have not confirmed it.
this truck will stay stock while i own it except for exhaust/intake elbow bolt on stuff. I have a mustang to go fast.
While i have the top end out changing the HPOP, what else should i "upgrade"? longevity is what im after of course.
is the updated cover worth getting if there are no chaffing problems as of yet? (that i know of anyways)
i feel like im forgetting some other parts i have read about. blue fuel spring, for example, what is that for?
Thanks guys!
FICM is a reman.
Thanks guys!
