1 - 5 of 5 Posts
2003 6.0l bulletproffed powerstroke. No hot start, replaced ipr and icp, looking for other solutions that hopefully aren't very invasive. Has also had a HPOP recently. Builds oil pressure when cranking on cold start and will start(obviously), doesn't show oil pressure building when cranking when hot. Bad lPOP possibly?
Need to get a gauge on there to be sure, the oil sender is just a switch(7psi) -- so the oil gauge is basically a glorified idiot light
You could pull the pressure regulator and check to see if the piston moves freely(near the crank pulley)
Also to add that I pulled the oil filter and cranked on it and the filter reservoir does fill when cranking if that makes a difference
1 - 5 of 5 Posts
