· Premium Member
Have a 03 6.0 no crank, no reverse lights , no back up sensor stuck in 4 low electronic 4 wheel drive. Has new hpop, new ipr , new icp, pulled ficim and PCM and put them both in another 03 that one started and ran fine. Reinstalled in my truck and it fired right up and ran fine. Tightened every thing up took it around the block and it was stuck in 4 low and then kept stalling out and would move 100 feet and stall again nursed it back into my driveway and it stalled again this time no crank. And also both my SCT tuner and my scan gauge 2 power up when pluged into obd2 but say unable to connect. Checked all fuses with fluke all good checked pins on obd2 has power. PCM has power jumped the starter with wire on passenger side and it cranked but no start. Checked all chaff spots nothing totally lost at this point. Any help will be greatly appreciated thanks. Oh and ficim is good.
· Island Dweller
Off the top of my head I would check the PCM connection
· Winning DUHHH
Check your 5vref at the map sensor. Sounds like a shorting circuit
Sent from AutoGuide.com App
· Premium Member
Checked all the PCM connections they are good did pin out readings all have power but I only had a 2005 6.0 pin out I would like to find a 2003 6.0 pin out also was wondering what resistance should be on 12 pin c1282 connector plug should be
