1 - 7 of 7 Posts
Is there a kit that a person can use to swap out the stock leafs in the front and upgrade to the front coils that the 05 and up trucks had?
Good question....but I dont think so.
I would like to swap my Excursion over to the 05+ front suspension...
I will not sink the money into a coil over conversion, but I would spend a few hundred on a stock coil conversion, I have most all the parts sitting around.
What kind of prices should I be looking for on an 05+ axle?
After that all I really need is the springs, and the arms right?
How much is the FullTraction kits, and I read they accept coilovers....but what if I just want to run a set of coils...like stock? Or 4" lift....
Most are at least a $1000 for a the front axle.
Occasionally you get lucky and find good deals like front and rear axles out of an 07 for $1100.
Coils, shocks, coil buckets, radius arms, radius arm brackets, tie rod, drag link, trac bar, etc... is needed to make the swap.
The Full Traction is setup for coilovers, as is you can't just run coil springs in the kit.
Full Traction is a much better designed and built kit vs. the Fabtech and the Skyjacker Z-link.
1 - 7 of 7 Posts
