Codes?I UPGRADED my HPOP hoses and added the cross hose because I had a leak, replaced O-Ring and worm clamp on turbo, went for test drive engine stopped and wouldn't start, got towed with a rope back to the house, had to top off the power steering fluid because I lost fluid while getting towed, found out the the fuel pump relay went out, bypass fuel pump relay, Now I hear this very annoying noise coming from the engine only when driving whenever the the TURBO spool to 5.5 psi and above, gradually gets louder.
