1 - 7 of 7 Posts
I have a with a 2002 7.3 powerstroke owned sense it was new. It started using alot of at 42000 it uses 1 quart to 100 miles almost exactly. It has been several ford dealers all the injectors o rings were replaced and number 8 injector recently been replaced. The turbo has been checked on the intake no oil leaks. The turbo was checked for end play as well. Were really at a loss the blow-by was also checked and it checks out all ok. Any Ideas or any help would be greatly appreciated.
Seeing any extra smoke from the exh.? Oil pooling in the valley? Oil in coolant? Just a few of the places I'd look anyways.
no that is thing that baffles me most is no extra smoke from the exhaust no oil the valley I'm not sure were would it all go it would have to drain from the valley I'm assuming your refering to lifter valley ? no oil in the coolant either.
Yeah, Several potential leak points in the engine/lifter valley. Has a drain hole at the rear that would make it look like the rear main seal was leaking. What oil are you using?
oil
He is using 10/30 non synthic. The are no mods done to it at all and there is no leaks that we and see or find the dealer went as far laying down a new white sheet and let it run to find nothing. the tailpipe is black but how can I tell if it soot from oil or the just plain exhaust ?
Hard to tell if its a small amount being burnt. Try 15W-40 (diesel rated - Delo and Rotella are popular diesel oils) at next oil change. Hopefully the thicker/heavier oil will slow any leaks or burning.
I agree completely with nccatfan. Though it may not seem like it there is a huge difference in weights of oils and additive packs for gas and diesel engines. Diesel oils are better suited to perform in higher heat conditions and are packed with additive to trap soot and HC's that might be floating around in the oil. Also 10w30 engine oil can thin up when overheated and suck right up past the rings. I would use 15W40 in all Ford diesels unless you are operating in a cold weather climate where temperatures are reaching below freezing.
:icon_ford:
1 - 7 of 7 Posts
