1 - 10 of 10 Posts
· Premium Member
Is it charging?
· Premium Member
Then have the batteries load tested. They must be disconnected to do so. How old are they?
If they pass start looking for chafed wiring
· Registered
ok, i will do that. one battery is 1 year old the second is +3 years old.
Thanks For the help.
I've always been told to replace both at the same time because the older weaker one will cause the new one to be at the same level as the old.
· Registered
I second that. Replace both batteries at the same time or the older one will pull the newer one down with it.
Chances are the older battery is starting to do that.
Also check the usual simple things like corrosion on the connections and so on.
1 - 10 of 10 Posts
