Hi, Just had a 2001 F350 7.3, manual tranny, 4x4 come in the shop. Owner said truck would just randomly die. Drove truck and it would die while driving. When it would do this I let off accelerator pedal for a split second and then pressed on the pedal and truck took right off. Has a new fuel filter, no lack of power when you punch it. Hooked scan tool up, it said we had a bad cam sensor. Changed the sensor, put in the grey one with silver steel hold clamp. Checked with scan tool, cleared codes. Took for a drive again and it still does it, no codes either. Acts like the key is shut off when driving. Can the accelerator pedal do this possibly? Not sure what to check next. Injectors all test good, good oil pressure etc., on scan tool while driving. Thanks for the help.
