Hi all first I'd like to thank you all for running an amazing site, I've learned many things that I otherwise would of had no clue about! This is my first post so I'll try to be as precise as possible. Please let me know what other kind of info you may need!
This story is a tad drawn out so I apologize in advance but hopefully will give you enough clues to get your head around it! I'm from Colorado Springs CO, I'm up in Denver Thursday doing some errands, driving around when I see diesel for $2.43 a gallon at a Shell station. Shell has never steered me wrong before and the price was 10 cents lower than the next station! So I pull in and put about 12 gallons into an already 1/4 full tank. Start her back up and all is well.
About 15 minutes later any throttle use at all produces a weird wheezy sound from the engine instead of the usual 7.3 "chug" and @WOT I can only do about 35 mph, 3 minutes after that I can only hold about 25 mph, 1 minute after that 5 mph, I get her into a parking lot and she stalls out. All attempts to restart result in a lot of cranking and no turn over. Noted the tach runs up during cranking. Also noted all dash lights seem to work as usual, ie. the WTS light still operates. There is no CEL.
Walked to Advance and picked up a fuel filter, drained fuel reservoir (noticed the fuel was a blue/green color), installed filter, "primed" reservoir (key off/on 5 times), turned key to start and the darned thing turned over! BUT! It only idled poorly at about 900 rpm for about 60 seconds then died again. Then lots of cranking but no turning over. Noted that during cranking and while it was running poorly for those few seconds there was no smoke from the tailpipe. Checked oil level, noted engine oil level is within limits and HPOP reservoir was 1 inch or so below plug (couldn't be precise as I didn't have a stick to measure at the time) Was getting late and couldn't work on it where I had it parked. Had it towed all the way back to my house in Colorado Springs the next day.
Thursday/Fridays guess: purchased bad fuel?
Saturday: I dropped the tank in the morning expecting to find algae or sticks or a broken fuel pickup or garbage or cheetos or a sandwich or SOMETHING but there was nothing, tank was immaculate! Strainers were clean, pickup was clean. Blew out the return line into a clean jug, was clean. So I ran some fuel line from the pump into a new clean jug of diesel, cycled the key 5 times with the reservoir drain open and cleaned out Thursday's diesel purchase. Noted the pump only fills the reservoir about 60% full during it's exact 20 second cycle (I thought normal was 30 sec but the fact that the pump ran for exactly 20 seconds timed, i don't know) and that the new diesel was yellowish in color. Replaced the filter, primed reservoir and tried to get it to turn over while pulling from the 5 gallon diesel jug. Nothing. Too dark to work on it more.
Saturday's guess: fuel pump? But why did it run for a few seconds Thursday but not today? And why can't I get it to turn over even for a few seconds with clean diesel in the reservoir? :dunno:
So here I sit rummaging forum threads. I do not have AE but have FORScan so can give some basic computer diag info in the morning but thought I'd get the collective brainstorm rolling now. I have an extra CPS that I can throw in but the fact it turned over once and the fact the tach runs up during cranking makes me kinda doubt that. I also have a new Delphi fuel pump that I will throw in tomorrow. I'm only a 2 year old in the world of diesels but I'm an old hat in general mechanics so if you point me at something or ask for more info about something I can probably deliver. Thank you all in advance for any help you can provide!
