1 - 1 of 1 Posts
· Registered
My F250 has started acting up. Normally when you get it and put the key in the ignition switch and either turn it to ACCY or START, the windows/wipers/washer would be able to be run, however now it literally takes 1-2 minutes before those even get power. I have replaced the GEM with a known good unit, and it hasn't changed anything. Anyone ever come across this, and if so what are the suggestions?
Thanks is advance
1 - 1 of 1 Posts
