I bought the truck 4 years ago with 240k on it. Didn’t have any history on it prior to purchase. Had a good friend at a diesel shop run some checks on it before I bought it. Compression was good on all 8 (380 psi or better) along with no codes and good fuel pressure (50ish psi) under hard load. All was good so I bought it. Right away I replaced many wear parts and did common upgrades to prolong reliability and performance. Hutch/harpoon mod done etc. not gonna list everything
Truck ran good and worked hard up until I put a hydra tuner on it 2 years ago as I wanted more power and firmer shifting for towing. Was all good for 6 months with the tuner until I burnt up the trans, bought a core to rebuild and swapped bad one out which went good. Problems with engine performance surfaced also such as low power on accel ,high fuel consumption, miss at idle, long crank when hot . Wanted to fix myself so bought forscan and torque apps to run tests and monitor. Cct failed cyl 8 with (7-8%) a few times (cps is the ford dark grey with purple) any way... everything else checks out
icp 500psi idle / 2800-3100 psi hard accel.
Ipr duty cycle is 9-11% @ idle and never above 55% under load with tune.
Fuel pressure (via mechanical gauge) 70-75psi @ idle and have seen it go down to near 40 psi when really mashing pedal.
Passed Buzz test all injectors sound good cold.
Cct showed cylinders 1-7 @ less than .75% during idle warm engine, cylinder 8 failed with 7-8 % on several occasions.
Cleaned ebp tube (is new and wasn’t obstructed)
No visible up pipe leaks as they look fairly new and are the bellowed newer version
No boost leaks (made leak tester).
No oil leaks anywhere other than some oil inside intake plumbing. I addressed this with oil catch can routed back to intake.
I replaced lpop with updated mahl pump as old one was leaking oil awhile back....lpop output is good.
Pulled valve covers over a year ago to look at injector spouts while running... they all were spurting the same amount. Injectors looked recently replaced also.
Truck still has same symptoms that started over a year ago. Not sure where to look next ...any input is appreciated. Thanks
